Topic: Replaced the Fuel Pump and Filter on the Onan 4000 Generator (Read 385 times) previous topic - next topic
Hi,
I replaced the Fuel Pump and Fuel Filter on the Onan 4000 Generator on "Hazel".  Before I did this the generator would start and run for a bit and then die.  But it was providing power to the coach while it was running.  However after I replaced the Pump and Filter it is not providing power to the coach.  Does anyone know what I might need to check.  All the breakers in the coach and the one on the generator are fine.
Thanks,
Marc
2006 23.5 FL
Re: Replaced the Fuel Pump and Filter on the Onan 4000 Generator
Did you disconnect any wires and forget to reconnect them?
I would triple check the breaker on the generator, jut to be sure.
Could also be the Automatic transfer switch (you should hear an audible click from behind the power center as it switches over).
The Lazy Daze Companion: Generators – Trouble Shooting
Rich,
Thank you!  I will check all those things again.  I have also printed the troubleshooting guide.
Marc
2006 23.5 FL
Glad to help.
If you tell us the year and model of the coach, the moderators will put it in the footer of your posts, and it will generally help people answer this kind of question.
If you unplugged the multi-wire cable from the bottom of the controller box when you moved it aside, double-check that the plug was firmly seated in the mating socket...
Glad to help.
The Coach is a 2006 23.5' Rear Bath.
2006 23.5 FL
I unplugged and reconnected it with an audible "click".
2006 23.5 FL
I don't know if it will help you, but I've found this resource to be useful in the past:
https://www.flightsystems.com/pdf/onan-rv-troubleshooting-guide.pdf
You will probably have to get a multimeter and start tracing where (if anywhere) the power is present.  Start with the generator output and work upstream or downstream from there depending on what you find.
