Topic: Water Spot Removal (Read 130 times) previous topic - next topic
Water Spot Removal
A few months ago I found that I had water spots on some of the fiberglass but only in a few areas which didn’t make any sense to me.
Nevertheless I tried a cleaner wax that has always been successful for me but that failed. I tried using a vinegar water solution and that failed.  Next I tried a gentle polishing compound and that also failed.
Somewhat reluctantly I ordered Meguiar's Water Spot Remover and much to my surprise it worked like magic.  I then used a marine-grade wax that has proven to be long-lasting and now those areas look good as new.
Amazon.com : meguiar's water spot remover
I thought this information might be helpful to anyone with the same water spot issue.
Re: Water Spot Removal
I use a 30% vinegar solution to soften water spots, the same vinegar solution  I use to kill weeds.
Amazon.com : Harris 30% Extra Strength Concentrated Vinegar for Home...
