Bathroom Faucet Repair October 12, 2025, 06:52:03 pm Finished overhauling the toilet - works great! but now I find I have a drip on the bathroom faucet. Took the knob off intending to take out the cartridge, but I cant figure out how to do it - doesn't look like any I've seen before.. Anyone have some wisdom here? No maker's markings that I can see...Thought about just replacing it but it'll be heck getting to the nuts under the counter.....
Re: Bathroom Faucet Repair Reply #1 – October 12, 2025, 11:36:51 pm You may find this helpful:Fixing the faucet 4 Likes
Re: Bathroom Faucet Repair Reply #2 – October 13, 2025, 10:19:47 am QuoteYou may find this helpful:Perfect documentation of a repair!!!jor
Re: Bathroom Faucet Repair Reply #3 – October 13, 2025, 02:10:27 pm Quote from: Andy Baird - October 12, 2025, 11:36:51 pmYou may find this helpful:Fixing the faucetperfect. that chrome ring was where i had to stop - had no idea it just pops off. thanks!
Re: Bathroom Faucet Repair Reply #4 – October 13, 2025, 04:57:58 pm In case the faucet still leaks, replacement faucets that fit are widely available at any hardware store.Removing the old faucet can be tough; LD glued it down with their usual polyurethane adhesive.If removing, apply several layers of tape around the perimeter of the old faucet to prevent damage during removal. I use masking tape and a 1" puddy knife with a sharp edge to get under the base of the faucet to cut the adhesive away.The connections under the sink are a pain to get to but they usually come loose without to much effort.Have fun Larry 2 Likes
Re: Bathroom Faucet Repair Reply #5 – October 14, 2025, 12:27:26 pm Well I got the faucet cartridge out easy enough, it looked perfectly clean but I soaked it in Line-Away anyway. A very slight improvement but its easy to see the 30 year old seals are toast. Guess I'll be looking for a new faucet. Pity we don't know who made it to see if a new cartridge can be had.
Re: Bathroom Faucet Repair Reply #6 – October 14, 2025, 01:12:44 pm Quote from: DesertDust - October 14, 2025, 12:27:26 pm Pity we don't know who made it to see if a new cartridge can be had.Well I'll be... when I bought the LD I got a file box that the previous owner said "has all the paperwork"They were not kidding...unfortunately, it doesn't cover the single-handle faucet in my bathroom.
Re: Bathroom Faucet Repair Reply #7 – October 14, 2025, 04:35:49 pm Hi DesertDust; I don't know if you need the shower diverter portion of the valve, but they are still available. This is one such: https://www.etrailer.com/RV-Faucets/LaSalle-Bristol/34420373W21.html?feed=npn&gad_source=1&gad_campaignid=21691392423&gbraid=0AAAAAD_vMtlZs7QVDmRGk4j1h96eItyuP&gclid=Cj0KCQjw6bfHBhDNARIsAIGsqLjKkDwpUAXyw3oPC-mW47Isnoa8Cybw4zvSa-sIhMXs1on0vdlW7NMaAt35EALw_wcB Spacing between the valves to fit the holes in your sink need to match. They might have replacement valve bodies also, and washer replacement kits. The ad for the Lasalle Bristol mentions the 'Utopia' name. RonB
Re: Bathroom Faucet Repair Reply #8 – October 14, 2025, 07:12:14 pm Quote from: DesertDust - October 14, 2025, 12:27:26 pmWell I got the faucet cartridge out easy enough, it looked perfectly clean but I soaked it in Line-Away anyway. A very slight improvement but its easy to see the 30 year old seals are toast. Guess I'll be looking for a new faucet. Pity we don't know who made it to see if a new cartridge can be had.Trying to find parts for antique RVs can be a challenge, the faucet was an inexpensive to begin with and may not have had replacement parts ever available. Few parts from that era are still available, forcing us to update to modern parts, sometimes requiring major modications.For example, todasay’s propane regulators are dimentionally different, requiring changing the plumbing..The good news is replacement faucets are widley available.Larry
Re: Bathroom Faucet Repair Reply #9 – October 16, 2025, 09:27:52 pm Broke down and replaced the faucet set with one from Walmart - $15.00I could NOT get the nuts that held the original faucet on loose. I ended up using a cutting disk on my dremel to chop it up until it all came out. A heatgun and spatula got all the old sealant off. new one dropped it and connected up perfectly.One thing though, manufacturing dust clogged up the nozzle almost immediately, had to remove and clean it.Faucet Replacement Pix 4 Likes
Re: Bathroom Faucet Repair Reply #10 – October 16, 2025, 09:31:41 pm Pictures of a job well done. 👏👏👏. Thank you for your follow-up post.
