Topic: Black Tank Elbow Fell Out (Read 1354 times) previous topic - next topic
Funny thing happened this morning with our ‘15 MB.  I had just dumped and was putting the black tank valve cover back on and it pipe felt loose.  One or two gentle wiggles later the elbow with the gate valve came cleanly off.  It just slipped out of the opening to the black tank.  The adjustable clamp is still in place. There are no apparent cracks. Pics attached.  Good thing it fell out after I dumped…
So, a couple of questions.  In re-inserting the elbow into the black tank, do I need to use ABS or PVC adhesive?  There doesn’t seem to be any glue residue on the end of the elbow.  If adhesive is needed is the elbow ABS or PVC?  If no adhesive is needed, then is the only task to re-insert and tighten the clamp?
Thanks for your thoughts in advance.
Don & Tery
2022 MB 27.5 towing a 2022 Wrangler
Re: Black Tank Elbow Fell Out
Our LD came with two hose clamps securing the black dump valve.
I suggest adding another hose clamp to double the clamping force.
Do you still own a 2015 and a 2022 LD?
His and her rigs?
Yea, just the two hose clamps. I just cranked down hard on mine when I put the black tank back in. Pick up a couple of new ones for peace of mind and a bright and shiny look. The LD boys went against their grain on this connection. I expected it to be glued in solid! Gotta say though, this setup makes valve installation a lot easier!
jor
09 27' MB
10  Suby Forester
Thanks for your solution.  Two clamps it is. Just pulled into a Walmart.
Good memory, Larry.  Yes, we still have the two MBs.  Not his and hers…north and south actually.  Although, if I mess up and end up in the domestic doghouse, I guess it might be his and hers (LOL).
Don & Tery
So if I had this situation, I might rough up the surface of the pipe a bit with some coarse sand paper, right where the clamps are, so that it wouldn't slip out so easily in the future.  I'm pretty sure that my dump ports are firmly glued into my tanks.  Then again I think I'll check that now while the tanks are empty.  Sounds like tightening those band clamps needs to be on my underneath inspection list.  RonB
We still have the two MBs.  Not his and hers…north and south actually.  Although, if I mess up and end up in the domestic doghouse, I guess it might be his and hers (LOL).
I would like to have as a second LD, located in the PNW, one of our favorite vacation places; it would eliminate a lot of driving. I doubt this is going to happen, but it is a nice fantasy.
Prepping for our first fall trip..
We would be careful that over tightening could crack the plastic. We would add something like this to the joint.
Fernco Proflex® 3 in. Cast Iron x Copper Flexible Coupling | Ferguson
Theresa & Everett  GLLDCC Making wonderful friends at LD rallies.
Surfside our 2018 31IB ( our current LD)   Sandcastle  2001 26.5MB ( our first LD)
Michigan born and home based. Traveling with our spoiled dog Dax.
I had a partly-full black tank when a piece of road debris (Route 10 East, in West Texas) knocked the valve loose- but not completely off. I didn't notice until a couple days later, at which time I made repairs.
When I got home I added a support bracket. Picture is below. Sorry it doesn't show the valve end of the bracket. I vaguely remember attaching it to one or two of the four machine screws that hold the valve to the piping. Could be imagining things, though. How does the saying go: "Of all the things I've lost I miss my mind the most!"?
Mark H.
Former owner, 1997-8 mid-bath
I did the same.
jor
09 27' MB
10  Suby Forester
I worried about same think happening on my '17 mb. Pipe had been attached to the fiberglass panel but that did not hold. I added 2 narrow aluminum strips - one on each side of the fiberglass for strength and then reattached the end of the black pipe. Fix done in June, 2018, with 12,000 miles. Now almost 38,000 miles with no problems.
file:///C:/Users/jhphi/Downloads/IMG_5586.JPG
file:///C:/Users/jhphi/Downloads/IMG_5594.JPG
file:///C:/Users/jhphi/Downloads/IMG_5590.JPG
2016 MB
sorry - here are pictures
2016 MB
Hey, Phil. Clever and nicely done!
jor
09 27' MB
10  Suby Forester
