Topic: kitchen sink replacement (Read 298 times) previous topic - next topic
Anyone know where to find a 25x17.5x4 inch deep single hole double bowl replacement sink for a 1997 rear bath 26.5 ?
1997 Rear Bath
Re: kitchen sink replacement
No suggestions on a source for a single sink, many have looked for years. The same goes for stainless steel sinks.
The major problem is finding a sink that is shallow enough for the drain to work. Too deep a sink will result in one that doesn't drain. To lower the plumbing to accommodate a deep sink would be a monumental task in most floor plans.
Let us know if you find something that works.
We found one a few years ago at Bontragers Bontrager's Surplus – RV and Home Improvement Items.    It is a surplus store just north of the Indiana border. They had a couple in stock at the time. I can't imagine there was a big demand for them. You can call them or.check their website.
Theresa & Everett  GLLDCC Making wonderful friends at LD rallies.
Surfside our 2018 31IB ( our current LD)   Sandcastle  2001 26.5MB ( our first LD)
Michigan born and home based. Traveling with our spoiled dog Dax.
Somebody on here modified drains and installed a single tub sink a while ago. JOR maybe
Jon
I used a single stainless 10 inch sink from Home Depot. Not much room for the drain and  No room for a p trap but it is nice to have a big sink
Jay
Hi JayWay:  There are other ways than a 'P' trap.  RV Waterless P Trap Self Sealing to Prevent Foul Odors - RecPro.  I'm not sure how well this would work. I have seen boating sinks that just had a drain on the side of the sink. (kind of a 'V' shape on the bottom back side of the sink.)
    Jor did have a picture of his kitchen sink with no 'P' traps. Maybe under the floor?
    Under kitchen sink plumbing          RonB
Here's a photo of my single tub sink. I never looked for a double tub. Maybe you'll have better luck than I in your search as I found it difficult to find a sink that would fit. This one took quite a bit of modification to get it in.
Ron is referring to one I used in another of our rigs. I was going to do the same in the LD but it would have made little difference so I went with the conventional p-trap.
Here's a photo of the plumbing under the single tub. The p-trap is actually in the compartment below.
jor
09 27' MB
10  Suby Forester
