Topic: TV removal and replacement 30TB (Read 1059 times) previous topic - next topic
We are looking to remove and replace the TV in the entertainment center in our 2001 30TB. I’ve been going through the forums, so I know it’s been done and is possible but I either can’t find good instructions on how to remove the TV or the links I find to instructions don’t work. Would someone mind telling me how to remove the TV or give me a good link to someone’s instructions? (it looks like there is a black rail of some sorts holding it in)
TIA!
2001 30' TB
Re: TV removal and replacement 30TB
Feel through the edge of the carpeting to locate screw heads holding the bracket. They may be 1/4" hex or #2 phillips.
Hi
I just saw your post about TV, I installed a swing arm TV mount on the left side of the TV box a 24" tv works perfect which allows for both cabinet doors to open without any problem. I also installed a shelf for a DVD in the box with some oak molding to match the wood paneling, as best as I could.
In the bedroom I put a piece of 3/4" furniture grade plywood above the header in the box. Heavy  layer of wood glue held in place with drywall screws and clamps until dry, then installed a Vizio flat TV mount.
Dennis
1997 30' Island Bed
