Topic: 2007, 31 ft LD, need to remove console to get to radio, no work now (Read 541 times) previous topic - next topic
I have unbuckled  two latches  on each side,  but removing -I need suggestions, thanks
Bob Wilson
2007 31 IB
Re: 2007, 31 ft LD, need to remove console to get to radio, no work now
Bob Wilson
I don't fully understand. I am guessing you might be talking about the dog house that covers the engine? If so the carpet wraps around it so well from the LD factory that it is hard to remove. I think there is only two latches, but wait for others to confirm.
Steve and Jill, Steve posting
1999 26.5 Mid-Bath
If you are referring to the doghouse, there are four latches. To make it less difficult, pop off the trim on both sides.
jor
09 27' MB
10  Suby Forester
Thanks everyone, there are 2 latches on both side of doghouse,  pulling it off will probably take some careful effort
Bob
2007 31 IB
Hi Bob;  Removing the 'doghouse' is the best, and nearly the only way, to get the radio in and out. There are two high latches, and as Jor said taking off the under dash covers will help that. Those covers just pull off with friction clasps. Those trim panels cover up the collision steel panels.
   The lower two latches have a fold down handle. Unfold the handle and unscrew the latch to release tension on the 'doghouse' hooks.  To get to mine, the factory covered those latches with carpeting.  The flaps of carpet over those release latches were screwed down. So I had to remove many of those screws right at the base.  Your 2007 may not have those screws.  I didn't replace any of the screws and the carpet flaps stay in place well. (until I try to vacuum that area).  If you add any wiring for the radio, it should be placed in plastic wire loom (Harbor Freight) and ty-wrapped up out of the way. The wiring will droop down when you are trying to get the 'doghouse' engine cover back on.
    It took about 3 minutes to get the cover off/on in my old Dodge. (not LD)  It takes about an hour or three to get the cover off and back on for the older Lazy Dazes.  New LD's seem easier with less carpet involvement.   RonB
Thanks Ron
Bob
2007 31 IB
I had someone install my radio, but here is a photo of the install for my 2017 TK, doghouse was not removed.
I know it is 10 years newer but I doubt there is little difference as my cab looks just like the E450 cab of my 2004/2006 rentals.
Dave
2017 TK
OK thanks,  will keep this in mind, have not made a move yet
Bob
2007 31 IB
A very nice upgrade, Dave!
  have changed my mine, will not replace radio.  I am selling my rig and the new owner can replace what he or she wants
rather than what I would replace.
Thanks everyone
Bob
2007 31 IB
