Topic: Water heater  (Read 786 times) previous topic - next topic
Water heater
 Water heater will not light for more than s few seconds. It is trying 3 time before lockout. I have replaced everything except the off on switch and tank. Any ideas what is wrong.
Dennis
1997 30' Island Bed
Re: Water heater
Hi Dennis;  Does the flame look and sound like what it should be when it is on?  If so the igniter tip may not be sensing the flame. It cuts off the gas and tries again.  The free electrons in the flame conduct electricity to confirm to the logic electronics board, that the flame is lit. Try lightly sanding (clean) the tip and see if that fixes it.
   I copied this from the IRV2 forum:
       "Re-position spark electrode so tip is engulfed in flame....gets red (maintain 1/8" spark gap)
        Make sure flame spreader is straight/parallel to end of burner tube
        Check that high voltage wire from transformer on board has clean/tight connections on both ends
        Check that mounting screw for spark electrode assembly is clean/tight  (provides ground)
               Replacing the circuit board is LAST option........."      I hope this helps.   RonB
Re: Water heater
The water heater is very sensitive to poor electrical connections. The spark gap needs to be within specs.
I suggest a full tune-up before buying any additional parts.
Here is a video that goes through the basic tune-up procedure.
https://www.youtube.com/watch?v=GXtp_2sA8Ao
You will need a multimeter.
Re: Water heater
Hi Larry, a good video, but a few comments... He had it all apart but he didn't say he cleaned the tip of the igniter.  My opinion is that it can provide a spark (very high voltage) no matter how clean it is, but the small current through the plasma that provides a signal back to the control board, needs a better connection, causing this problem if it is dirty.
   He did mention adjusting the flame spreader, which could be dirty, deflecting the flame away from the igniter tip, but he didn't say if he did adjust it.  He should have made it clear that the thermal fuse is a fuse, and if it is open, it has to be replaced. Usually this fails if the flame through the heat exchanger tube is partially blocked and blows back to the location of the fuse.  He could have added that the ECO switch is "electric cut off'.
   I would have mentioned 'soot build up outside' as an indicator that the air/fuel mixture needed adjusting for more air. He did mention that altitude affects that mix ratio. And yearly the plastic plug should be removed to clean the tank of particulate matter, or inspected. A lot of that depends on how 'hard' the water you generally use is.
    One trouble I have seen in person is connector pins to the control board, that had moved out of position in the white plastic shell. Pushing the one connector back into the shell to properly seat, fixed it.  (I think that was a factory defect that didn't show up as a problem until after a few years.)   RonB
Re: Water heater
90% of the problems I have found with the Atwood water heaters are caused by poor electrical connections, renewing all the connections usually solves the issue. I have found the spark gap set too wide on many heaters, it should be about 1/8".
The control boards occasionally go bad. Dinosaur makes a good replacement.
I carry an extra board, along with a spare thermal fuse that has been 'borrowed' a few times at Caravans and GTGs
 to get someone through the event until replacements can be obtained.
Re: Water heater
Thanks to you all  for the information. I did clean the spark igniter and made sure they aline and set gap to 1/8", did not clean where the assembly to the flame tube will clean it and make sure that round thing is centered.
I was in the old LD group for a long time and stopped using it. Just found this site a few days ago. Glad to be back. We live in Bend oregon area. We have a 1999 green 30' we  bought in J̌une 2004.
P.S. the flame sounds normal for 10 seconds or so.
1997 30' Island Bed
Re: Water heater
Hi Dennis, Welcome back!  We have lots of archive entries and The very useful Companion as sources of information concerning just about anything. The Search function can shed light on many issues.
   So you said " the flame sounds normal for 10 seconds or so."   Then what?  Does it fade away, or abruptly shut off?
Do your flames on the cooktop look normal?  I'm wondering if you have a pressure regulator problem or some contamination in the propane.  If your space heater works normally then the issue probably is with the water heater.  RonB
Re: Water heater
Hi Dennis, Welcome back!     So you said "The flame sounds normal for 10 seconds or so."   Then what?  Does it fade away, or abruptly shut off?
Do the flames on the cooktop look normal?  I'm wondering if you have a pressure regulator problem or some contamination in the propane.  If your space heater works normally then the issue probably is with the water heater.  RonB
Propane pressure regulators wear and age, eventually needing replacement. The fabric diaphragm inside the regulators hardens and cracks. If this happens, you can get a nice propane leak. Consider replacing it if your LD still has the original.
The propane systems should be set at 11 inch/pound H2O with two propane appliances running. I run the water heater and furnace` during the pressure adjustment. If you try to adjust the pressure with nothing running, the pressure will be too low for the proper operation of any of the propane appliances.
A manometer of some sort is needed. A traditional manometer is made of tubing and is very accurate and easy to make. YouTube has many videos on how to build one.
https://www.youtube.com/watch?v=gsI6wOeqRlI
I use an electronic manometer I bought 12 years ago. Its readings match the old tubing manometer I made a few decades ago.
Amazon.com: PerfectPrime AR1890 Professional Digital Air Pressure Meter &...
If you are not willing or qualified to deal with the potential dangers of working with propane, have a professional install and/or set the pressure. We don't want anyone or anything getting hurt.
Re: Water heater
Thanks Larry, I will get a new regulator. Hope that's the problem.
1997 30' Island Bed
Re: Water heater
It's not necessarily the cause of your propane problem but changing the old regulator is a good preventative maintenance item. If original, 26 years is a long time.
Re: Water heater
Thanks for the information very helpful I just bought a 1985 lazy daze in amazing condition original interior a couple fixes but other than that it’s great
Jasmine Alas,  22' 1985 Rear Bath
Re: Water heater
Welcome aboard.
There are still a few of us who owned 1980 era LDs and still remember how things work and break.
Let us know if you have questions.
One point, make absolutely sure the roof, end caps, and, most importantly, the front window and cap seams are well sealed.
Almost every pre-1990 LD I have looked at or worked on had front-end rot from leaks around the window and front cap seams. The front corners are particularly susceptible to leaks and rot.
Re: Water heater
Dennis
Hi All
Replaced the propane regulator, still did not work.
Looked at the exhaust vent, there was a black mud daubers nest plugging the entire tube at the end, cleaned it out, still did not work.
Had my new circuit board checked, it was no good, bought a new one, still did not work.
Everything was new including solenoid valve, circuit board, thermal cut off kit including new EOC thermostats, spark probe gap set at 1/8", propane regulator, still did not work.
Finally checked the connection between the bracket that holds the main burner to the flue tube, the hole was stripped, so the screw would not tighten, I cleaned both surfaces and used a larger screw and added vent covers to the exhaust tube.
Problem fixed, works like new!
Thanks again everyone for you help
1997 30' Island Bed
Re: Water heater
So, bad ground?
Re: Water heater
Yes it was a bad ground  the screw would not tighten, so the two pieces would wobble and not make a good ground
Dennis
1997 30' Island Bed
