Topic: Loctite pl-s40 (Read 198 times) previous topic - next topic
Loctite pl-s40
I have decided to use the loktite pl-s40 instead of traditional dicor....that being said what is the general consensus when it comes to getting semi even coverage?
I’m figuring the loktite isn’t self leveling so what is the best practice for leveling/smoothing out around a replaced roof vent/antenna? Biggest worry is creating air bubbles and voids while trying to get a clean smooth sealant application.
Thanks for any advice
2000 RB
Re: Loctite pl-s40
Clean surfaces before sandwiching the sealant. Acetone (quickly dry it off painted surfaces), followed by propanol.
Re: Loctite pl-s40
What about around vents? The sealant protecting the gaskets?
2000 RB
Re: Loctite pl-s40
If you are applying over existing sealant, scrub with brush and soap solution, rinse, and apply 90% propanol to dry completely. If a cleared-off seam, then the acetone-propanol treatment.
