Topic: Broken Spring Toilet (Read 275 times) previous topic - next topic
 Today the spring broke on the pedal assembly. Given that this is a 2006 wondering if it would be advisable to replace the water flush valve at the same time?
Also, does the toilet have to be removed to replace the cartridge?
Does anyone know which model toilet is used on the 30' IB? From the manual I assume it is either the 2011 or 511. Parts are same so doesn't matter but I am curious. I removed the cover but there was no label.
Jim
Re: Broken Spring Toilet
We have a 2006 30' anniversary edition and it has a Dometic Sealand Toilet Mo # 511 PLUS (the model # is on the pedestal under the cover). They make 2 different cartridges one has a white end on it and the other has a black end on it. Ours has the white end (part # for the spring cartridge - 385236096) Amazon has the part.
2006 50th Anniversary Blue/Gold Edition
As far as replacing the flush valve that's your call, I didn't.
You don't have to pull the toilet to replace the spring cartridge. Just take the plastic cover off the flush lever and there are 2 screws that hold the flush valve and the spring cartridge. There is supposed to be a third screw behind the flush valve holding the spring cartridge in. Depends on whether it has been worked on before.
Maker sure you get the assembly with the brass axle, not the older plastic one. In all likelihood, what broke on your toilet was not the spring, but the plastic shaft. Happened to me on my 2003 a few years ago. Sealand switched over to brass later on, but just in case there are still older plastic-axle kits out there--be sure you get the metal one!
I've ordered the parts. The ball still pivots when you rotate the pedal. Would that mean that the shaft isn't the problem?
Jim
"The ball still pivots when you rotate the pedal. Would that mean that the shaft isn't the problem?"
Probably. When the shaft breaks, the ball doesn't move when you step on the pedal. So you may actually have a broken spring (or maybe a broken part where the spring attaches).
