Topic: Ford E-450 Cutaway - rear axle ratio code (Read 378 times) previous topic - next topic
Hello everyone - please take a moment and post your rear axle ratio code. Per the attached picture:
If you do not know the axle ratio of your vehicle, check its Truck Safety Compliance Certification Label (located on the left front door lock facing or the door latch post pillar). Below the bar code, you will see the word AXLE and a two-digit code. Use this chart to find the axle ratio that corresponds to that code:
Rear Axle RatioNon-Limited SlipLimited Slip
4.10
52/56
E2/E6
4.56
58/83/85
E8/F3/F5
I am most interested in knowing if the axles are non-limited slip or limited slip. Thank you!
Note: this information and picture were pulled from page 17 of the Ford RV & Trailer Towing Guide - see attached PDF.
Chet in Yorktown, Virginia
Re: Ford E-450 Cutaway - rear axle ratio code
1988 MB  Ford E350, 4.10 ratio, Transmission G C6, Axle 52.
Rodney
1988 Mid Bath
The G-30 and E350s have 4.11 ratios
E450s have 4.56.ratios.
I have never seen an LD, Factory equipped, with limited-slip.
No reason why you could've one installed but expect to spend a lot of money, few mechanics works on these monsters .
Axle rebuild-D70 HD | Flickr
LD orders the chassis in bulk, AFAIK, all are equipped the same.
I have a 2014 27MB.  It has a 4:56 non LS axle.  It is OK, so far, in the slippery stuff.  This is likely due to the weight on the rear axle and the dual rear wheels.
When talking to Todd about placing an order, I explained that I really wanted the limited slip rear axle option on the chassis, which was, at the time, a $700 option from Ford.  Todd stated "We don't do that."
I suspect that with the small number of coaches that Lazy Daze orders, they may not have the ability to specify anything beyond the basic, stripped down model.  Our cab is pretty spartan.
Harold
2014 27 MB
Happy wife=Happy life
With our '83, G-30, the only time through ice, snow, or mud I detected any slippage was at the Albuquerque Balloon Fiesta after 4" of rain overnight. The 20' or so of mud we traversed to the gravel camp road showed both duallies flinging mud, progress was steady, and we reached the road with no issues other than a severe mud buildup on both sides to later hose off the chassis. Hard to see ho LS would have made any difference.
This is always a hoot to watch, not a Lazy Daze, tho:
https://www.youtube.com/watch?v=zRlxnKpXUmQ
I was told the same thing 16 years ago.
We have driven Some very iffy roads, in all sort of weather, and never experienced wheel spin.
I do carry snow cables in the winter.
This is always a hoot to watch, not a Lazy Daze tho
It did quite well considering the size and weight....and without limited slip.
ARB does have a air locker, for the D70 rear axle.
DANA 70 ARB RD172
DANA 70 ARB RD172
Yes, on my Jeep I installed and ran ARB air-lockers and 4.88 gears on the front and rear axles. After five or so years I pulled everything, went back to stock 3.73s with the factory limited slip in the rear and a pocket-locker up front.
As you might imagine I recently switched back to Detroit Lockers with new 4.88 gears on the front and rear axles. Front axle was swapped for a high-pinion unit. My son enjoys working on vehicles and breaking them so I though it would be a great time to teach him about setting up hypoid gears. These Dana axles had the shims inside of the pressed on bearings so setting up gear patterns and backlash was especially time consuming.
For street use and especially an RV it seems to me as of the stock open differential is best for most every application. I can never imagine taking a new LD down a bumpy dirt road let alone anything worse. Yikes!
