Topic: no electric power front  (Read 255 times) previous topic - next topic
I have no 120v or 12v front of rv that powers the tv. all other recepticles work otherwise,  I check all breakers in power panel and fuses, is there somewhere else that may have a fuse blown or reset?
2002 30' IB
Re: no electric power front
The TV should be on a 12V circuit unless someone changed it to a 120V TV.  Quick question please ... has the 12V socket for this TV been working recently?  And have you tested the 12V socket with something other than the TV?   Also I want to mention to make sure the rocker switch is turned on for the 12V socket for that TV.  (I had once accidentally turned it off while dusting that area and then wondered why the TV was working.)  Finally, there's an in-line fuse on the back of the TV in a somewhat flimsy plastic case.  Our plastic case cracked causing a lose of power to the TV.   So hope some of this useful.
It was changed to a 120v TV years ago, have no power at receptical, thanks for your response.
2002 30' IB
Checked all circuit breakers?  On my 2001 30TB my outlets are all through my GFCI breaker, reset if you haven't already.  I also have a switch on the wall in the cabinet left of the tv that controls the tv outlet(inverter/converter?).  Let us know what you find.
